Code Library – Changing element from view restarts the element
Solved1.77K views31st March 2021code library QAction
Jens Vandewalle [SLC] [DevOps Advocate]9.85K 29th March 2021 0 Comments
I'm executing below code to move my element from one view to another. I noticed that this results in an element restart while this isn't the case when changing the element from view in Cube. Is there some configuration that I need to add to make sure that the element doesn't restart?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 31st March 2021
Laurens Moutton [SLC] [DevOps Enabler]9.55K Posted 29th March 2021 0 Comments
Hi, see task 150671.
The problem is that the Update() is now also passing the port information. When setting value null (no change) then there won't be a restart of the element but we're using an SLNet call which doesn't have eg nullable booleans so we are forced to set a value even if there is no change. We're still investigating on how to circumvent this.
