Clear parameter values on Tables
Solved1.43K views27th May 2025driver option protocol.leave SetParameterDescription
Jose Araujo [DevOps Advocate]1.01K 25th May 2025 0 Comments
Hi
I need to clear table 1100 — that is, delete all its values.
I tried running this QAction, but it didn't work.
1100 is table
1001 is parameter
1002 is parameter
1003 is parameter
1004 is parameter
(This part of QAction delete table)
object[] columnClearInfo = { 1100, 1101, 1102, 1103, 1104 };
object[] columnClearValues = {
newobject[0], // PK
newobject[0], // UUID
newobject[0], // Name
newobject[0], // State
newobject[0], // Chunking
protocol.NotifyProtocol(220, columnClearInfo, columnClearValues);
<Paramid="1101">
<Name>ServiceTableUUID</Name>
<Description>UID</Description>
<Type>read</Type>
<Interprete>
<RawType>other</RawType>
<Type>string</Type>
</Interprete>
<Display>
<RTDisplay>true</RTDisplay>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1102">
<Name>ServiceTableService</Name>
<Description>Service Name</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1103">
<Name>ServiceTableStateService</Name>
<Description>Service Status</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1104">
<Name>ServiceTablechunk</Name>
<Description>Chunk</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1100"trending="true">
<Name>ServiceTable</Name>
<Description>Table Of Services</Description>
<Type>array</Type>
<ArrayOptionsindex="0"options="key" >
<ColumnOptionidx="0"pid="1101"type="retrieved"options=";save" />
<ColumnOptionidx="1"pid="1102"type="retrieved"options=";save" />
<ColumnOptionidx="2"pid="1103"type="retrieved"options=";save" />
<ColumnOptionidx="3"pid="1104"type="retrieved"options=";save" />
</ArrayOptions>
<Information>
<Subtext>
<![CDATA[Table Of Services]]>
</Subtext>
</Information>
<Display>
<Positions>
<Position>
<Page>Services</Page>
<Column>0</Column>
<Row>0</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Typeoptions="tab=columns:1101|0-1102|1-1103|2-1104|3,width:350-220-112-100,sort:STRING-STRING-STRING-STRING,lines:10,filter:true">table</Type>
</Measurement>
</Param>
Jose Araujo [DevOps Advocate] Selected answer as best 27th May 2025
Miguel Obregon [SLC] [DevOps Catalyst]22.32K Posted 25th May 2025 1 Comment
Hi Jose,
To remove rows from a table, you could use the following methods:
  • Method ClearAllKeys
  • Method DeleteRow: In this case you need the index of the row. You can get the index of the row using GetKeys.
Hope it helps.
Jose Araujo [DevOps Advocate] commented 26th May 2025
Hi Miguel,
I use protocol.ClearAllKeys(1100); but no clear the table.
