Clear parameter values on Tables
Solved2.24K views27th May 2025driver option protocol.leave SetParameterDescription
Jose Araujo [DevOps Advocate]1.01K 25th May 2025 0 Comments
Hi
I need to clear table 1100 — that is, delete all its values.
I tried running this QAction, but it didn't work.
1100 is table
1001 is parameter
1002 is parameter
1003 is parameter
1004 is parameter
(This part of QAction delete table)
object[] columnClearInfo = { 1100, 1101, 1102, 1103, 1104 };
object[] columnClearValues = {
newobject[0], // PK
newobject[0], // UUID
newobject[0], // Name
newobject[0], // State
newobject[0], // Chunking
protocol.NotifyProtocol(220, columnClearInfo, columnClearValues);
<Paramid="1101">
<Name>ServiceTableUUID</Name>
<Description>UID</Description>
<Type>read</Type>
<Interprete>
<RawType>other</RawType>
<Type>string</Type>
</Interprete>
<Display>
<RTDisplay>true</RTDisplay>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1102">
<Name>ServiceTableService</Name>
<Description>Service Name</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1103">
<Name>ServiceTableStateService</Name>
<Description>Service Status</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1104">
<Name>ServiceTablechunk</Name>
<Description>Chunk</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1100"trending="true">
<Name>ServiceTable</Name>
<Description>Table Of Services</Description>
<Type>array</Type>
<ArrayOptionsindex="0"options="key" >
<ColumnOptionidx="0"pid="1101"type="retrieved"options=";save" />
<ColumnOptionidx="1"pid="1102"type="retrieved"options=";save" />
<ColumnOptionidx="2"pid="1103"type="retrieved"options=";save" />
<ColumnOptionidx="3"pid="1104"type="retrieved"options=";save" />
</ArrayOptions>
<Information>
<Subtext>
<![CDATA[Table Of Services]]>
</Subtext>
</Information>
<Display>
<Positions>
<Position>
<Page>Services</Page>
<Column>0</Column>
<Row>0</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Typeoptions="tab=columns:1101|0-1102|1-1103|2-1104|3,width:350-220-112-100,sort:STRING-STRING-STRING-STRING,lines:10,filter:true">table</Type>
</Measurement>
</Param>
Jose Araujo [DevOps Advocate] Selected answer as best 27th May 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 25th May 2025 1 Comment
Hi Jose,
To remove rows from a table, you could use the following methods:
  • Method ClearAllKeys
  • Method DeleteRow: In this case you need the index of the row. You can get the index of the row using GetKeys.
Hope it helps.
Jose Araujo [DevOps Advocate] commented 26th May 2025
Hi Miguel,
I use protocol.ClearAllKeys(1100); but no clear the table.
Tiago Pina [SLC] [DevOps Member]476 Posted 25th May 2025 1 Comment
Hi Jose
When you want to clear an entire table, the most efficient approach is to use the clear action in the XML. This way, you don't need to retrieve all the keys in the QAction; you simply execute protocol.CheckTrigger(Id)
Regards
Jose Araujo [DevOps Advocate] Posted new comment 26th May 2025
Hi Tiago,
I use this in my Qaction before fill columns
protocol.CheckTrigger(1100); //table
protocol.CheckTrigger(1101); //parameter1
protocol.CheckTrigger(1102); //parameter2
protocol.CheckTrigger(1103); ////parameter3
And in my XML
<Action id="9">
<Name>services</Name>
<On id="21">parameter</On>
<Type>clear</Type>
</Action>
But didn't work, when QAction is running add new line but no clean my table.
Joshua Wong [SLC] [DevOps Advocate]649 Posted 27th May 2025 1 Comment
Hi Jose,
ClearAllkeys as mentioned by Miguel should work but if it doesn't, could you give more clarity to the situation you are facing?
When do we want to clear the table? Perhaps we want to make the table volatile if we want to clear the table on restart?
Do we need to save all the table columns?
What are we doing to fill up the table? is the fillarray being done right after we do protocol.ClearAllKeys(1100)?
Jose Araujo [DevOps Advocate] Posted new comment 27th May 2025
Jose Araujo [DevOps Advocate] commented 27th May 2025
Hi Joshua,
I initially tried using protocol.ClearAllKeys(1100);, but it didn’t seem to work. Then I changed it to assign the result to an object like this:
object result = protocol.ClearAllKeys(1100);
and it started working. I'm not sure why storing the return value made a difference, but it resolved the issue.
