Clear Action and Clear on Display For Stand Alone Parameter
Solved2.83K views27th March 2023action clear database protocol
Geovanny Galeano [SLC] [DevOps Advocate]800 18th August 2020 0 Comments
I'm trying to do something simple which is to clear the value of a parameter when the value of another parameter changes.
I want the parameter to be "Not initialized" rather than empty therefore i don't think this is possible from a Qaction.
I'm currently calling a trigger with two actions a "clear" and "clear on display"
After this executes the value of the parameter is set to "Not initialized" both in the client and server since if i do a GetParameter at this point null is returned.
The issue now occurs if i restart the element since this parameter has the save="true" the values before the clear come back and it shows both in the client and server.
Is there something else i need to do to clear the values in the database??
Geovanny Galeano [SLC] [DevOps Advocate] Selected answer as best 27th March 2023
Brent Alleweireldt [SLC]2.22K Posted 18th August 2020 2 Comments
If the value does not need to be persisted between element restarts, then you should simply remove the save="true" from the element. This way the value will only be kept in memory but will not be saved to database.
Thijs Vanovenacker [SLC] [DevOps Advocate] Posted new comment 19th August 2020
Geovanny Galeano [SLC] [DevOps Advocate] commented 18th August 2020
Hi Brent, I do need the value to stay in case of a restart, I should have mentioned that.
I only want to set that parameter to “Not initialized” when another parameter changes and if I restart it should stay as “Not initialized”. I still want the original values to stay if a change was not detected, but an element restart takes place.
Thijs Vanovenacker [SLC] [DevOps Advocate] commented 19th August 2020
Be careful with removing the save option on a parameter for a protocol with an existing element. This means that new value updates will no longer be pushed towards the database. The old/last value will still be in the database. On element (or DataMiner) restart the old/last value will still be returned and pushed back.
To overcome this, you can recreate your element. That way you start with a clean elementdata workspace for your element.
Another way is to manually remove the record from the ElementData table in the database. (Be careful when removing data from the DB)
