Cisco Nexus connector – Bandwidth Utilization Metric
Solved2.43K views23rd September 2020CISCO Nexus
Thomas Gunkel [SLC] [DevOps Enabler]1.23K 18th September 2020 0 Comments
Cisco Nexus driver exposes a "utilization" metric (in Mbps) per interface on the "Interface Detailed" data page.
Does the value stand for the RX or TX utilization or probably the summary of both?
Thomas Gunkel [SLC] [DevOps Enabler] Selected answer as best 23rd September 2020
Joey Vanhalst [SLC] [DevOps Advocate]2.17K Posted 21st September 2020 1 Comment
There are dedicated tables for TX and RX interface details in the Cisco Nexus. These tables contain statistics (for example bitrates for the TX or RX interfaces respectively). More details can be found in the help.
The "Utilization" in the Detailed Interface Info table will depend on the duplex mode of the interface.
  • Half Duplex: highest bitrate (TX or RX)
  • Full Duplex: TX + RX bitrate
Thomas Gunkel [SLC] [DevOps Enabler] Posted new comment 23rd September 2020
Thomas Gunkel [SLC] [DevOps Enabler] commented 23rd September 2020
Thanks very much Joey! Would be great to add that level of detail to our driver help.
