Cisco DCM Input TS stream to Output TS stream mapping
Solved1.59K views17th February 2021
Randy Ulvenes [SLC] [DevOps Member]1.31K 9th February 2021 0 Comments
This question is in regards to the Cisco DCM.  Is there a use case or a way to map the TS input to the TS output in a visual or a dashboard?
The DCM will change the multicast IP received on an input card to a different multicast IP on the output card.
Randy Ulvenes [SLC] [DevOps Member] Selected answer as best 17th February 2021
Jorge Dias [SLC] [DevOps Enabler]5.35K Posted 9th February 2021 1 Comment
If you use 'Transparent Loop Through TSs' you can directly know by looking at column 'Active Input TS (Output TS Loop Through)' (pid: 12116). Each entry on that table has a 1-1 relation on the OutputTSs.
If you use 'normal' OutputTSs you will have to check service by service. On the Output Service Table you have column 'Active Input Service FK' (pid: 1943), the transport streams then are the first three numbers of that key (same for the Input TS).
E.g.:
Randy Ulvenes [SLC] [DevOps Member] commented 9th February 2021
Thank you Jorge! That is what I needed to know.
