Cassandra Reaper not using Shiro auth
Solved1.86K views19th April 2024authentication Cassandra Reaper
Oscar Eves [DevOps Advocate]356 18th April 2024 0 Comments
I have setup Reaper to use Shiro auth like so;
accessControl:
sessionTimeout: PT10M
shiro:
iniConfigs: [“classpath:shiro.ini”]
However no matter what users I specify in the shiro.ini file it only allows me to login as the default admin user with ‘admin’ as  password.
Relevant part of Shiro config
[users]
user1 = password, admin
[roles]
admin = *
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th April 2024
Felix Wesemeier [DevOps Catalyst]2.53K Posted 18th April 2024 1 Comment
Hi Oscar,
can you try to use file: instead of classpath:, e.g.: iniConfigs: [“file:/etc/cassandra-reaper/shiro.ini”]
This worked or me.
Please find below shiro.ini config-parts with encrypted passwords:
[main]
authc = org.apache.shiro.web.filter.authc.PassThruAuthenticationFilter
authc.loginUrl = /webui/login.html
sha256Matcher = org.apache.shiro.authc.credential.Sha256CredentialsMatcher
iniRealm.credentialsMatcher = $sha256Matcher
filterChainResolver.globalFilters = null
[roles]
operator = *
user = *:read
# default authentication is the following hardcoded admin user
[users]
admin = PasswordHashHere, operator
otherUser = PasswordHashHere, operator
You can create a hash with one of the following commands:
echo -n “YourPassword” | shasum -a 256
echo -n “YourPassword” | sha256sum
Ref: cassandra-reaper.io/docs/configuration/authentication/
Regan Hughes [DevOps Member] commented 18th April 2024
This is awesome Felix, it worked! Thank you.
