Cannot Read Properties of Undefined (Web/Text Component in LCA)
Solved1.02K views27th March 2025
Kobu Selvarajah [DevOps Member]66 25th March 2025 0 Comments
Hello,
When attempting to add a {COMPONENT} feed to an HTML or a Text widget, we receive an error message: "Cannot read properties of undefined (reading 'replace').
This appears to be specific to our application (LCA).  For example, the error still occurs when the existing LCA is duplicated.  On a brand new empty LCA, there are no errors.
Although the page is loaded with errors in the F12 Developer Tool of our web browsers, we're not able to see anything specific to the error message above.
We are currently running DataMiner (10.4.12.0-15149).
Any insights on this issues?
Thank you!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th March 2025
Wout Mahieu [SLC] [DevOps Catalyst]11.53K Posted 26th March 2025 1 Comment
Hi Kobu,
While I cannot tell you why this error occurs in the specific LCA you are building, I can say that this issue is most likely fixed in a newer version of the Web apps. I suggest that you perform a Web-only upgrade to a more recent version and check if the issue still occurs. A web-only upgrade will only upgrade the web apps without any DMS downtime.
Kobu Selvarajah [DevOps Member] Posted new comment 26th March 2025
Kobu Selvarajah [DevOps Member] commented 26th March 2025
Thank you Wout! I believe this issue carried over when we upgraded the DataMiner from 10.4.10.0 to 10.4.12.0.
Gilles' suggestion did the trick in getting the {COMPONENT} function to work again.
Thanks again!
