Cannot load complete visio on Edge
Solved1.93K views21st November 2023
S R K Chowdary Alla157 25th October 2023 0 Comments
Dears,
I have an issue only on one PC, where Element has two Frame synchronizers, First synchronizer loads the visio, and able to control , but second synchronizer cannot pull full visio and also no control. It happens only on one PC with all users, But both visios work perfectly on other clients..
Any help?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 21st November 2023
Jeeva Suria Rajah [SLC] [DevOps Enabler]1.86K Posted 27th October 2023 2 Comments
Hi Chowdary,
In the System Center, can you try to change the default browser engine to Chromium (if it was in the default engine previously)?
Alternatively, you can also follow this guide in the DataMiner Docs to configure Microsoft Edge to run DataMiner Cube.
S R K Chowdary Alla commented 17th November 2023
Dear Jeeva,
Would you please check my pic which I have posted 30min before, as it showing some error to load the Visio.
Thx
Hi Jeeva,
I have copied Selenio files from other working System/Cache and now its working fine.
Thanks.
