Cannot load complete visio on Edge
Solved1.93K views21st November 2023
S R K Chowdary Alla157 25th October 2023 0 Comments
Dears,
I have an issue only on one PC, where Element has two Frame synchronizers, First synchronizer loads the visio, and able to control , but second synchronizer cannot pull full visio and also no control. It happens only on one PC with all users, But both visios work perfectly on other clients..
Any help?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 21st November 2023
Jeeva Suria Rajah [SLC] [DevOps Enabler]1.86K Posted 26th October 2023 2 Comments
Hi Chowdary,
Can you try to clean the Cube versions Cache, Visio Cache, and Protocol Cache?
Marieke Goethals [SLC] [DevOps Catalyst] Posted new comment 27th October 2023
S R K Chowdary Alla commented 27th October 2023
I am using Microsoft Edge to run Dataminer (not from Cube app), and don’t find this option to clean, except on the Edge cache, which I did, but didn’t work.
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th October 2023
Could you try to clean the DataMiner Cube XBAP cache as detailed here https://docs.dataminer.services/user-guide/Reference/faq/DataMiner_client_applications.html#how-do-i-reinstall-the-dataminer-cube-browser-app?
