Cannot load complete visio on Edge
Solved2.58K views21st November 2023
S R K Chowdary Alla191 25th October 2023 0 Comments
Dears,
I have an issue only on one PC, where Element has two Frame synchronizers, First synchronizer loads the visio, and able to control , but second synchronizer cannot pull full visio and also no control. It happens only on one PC with all users, But both visios work perfectly on other clients..
Any help?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 21st November 2023
Jeeva Suria Rajah [SLC] [DevOps Enabler]1.87K Posted 27th October 2023 2 Comments
Hi Chowdary,
In the System Center, can you try to change the default browser engine to Chromium (if it was in the default engine previously)?
Alternatively, you can also follow this guide in the DataMiner Docs to configure Microsoft Edge to run DataMiner Cube.
S R K Chowdary Alla commented 17th November 2023
Dear Jeeva,
Would you please check my pic which I have posted 30min before, as it showing some error to load the Visio.
Thx
Hi Jeeva,
I have copied Selenio files from other working System/Cache and now its working fine.
Thanks.
Jeeva Suria Rajah [SLC] [DevOps Enabler]1.87K Posted 26th October 2023 2 Comments
Hi Chowdary,
Can you try to clean the Cube versions Cache, Visio Cache, and Protocol Cache?
Marieke Goethals [SLC] [DevOps Catalyst] Posted new comment 27th October 2023
S R K Chowdary Alla commented 27th October 2023
I am using Microsoft Edge to run Dataminer (not from Cube app), and don’t find this option to clean, except on the Edge cache, which I did, but didn’t work.
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th October 2023
Could you try to clean the DataMiner Cube XBAP cache as detailed here https://docs.dataminer.services/user-guide/Reference/faq/DataMiner_client_applications.html#how-do-i-reinstall-the-dataminer-cube-browser-app?
S R K Chowdary Alla191 Posted 17th November 2023 0 Comments
HI Jeeva,
I cannot the see option which U have menionted, as Iam using Edge with DMA ver9.5, But whenever we try to open Selenio visio, iam getting following error below and Visio cannot load the parameters. Please advise.
S R K Chowdary Alla Answered question 17th November 2023
