Can you lock parameters for an element?
Solved2.16K views14th November 2022data IGMP locking Parameters
Stacey Taplin42 14th November 2022 0 Comments
Hello,
We are wondering if there is a way to lock a parameter such as the one below. Reason being we do not want it being accidently disabled by other admin users and general users. We always want it enabled, and for only certain people to be able to even be able to press the button here that would disable it.
Kind regards,
Stacey
Stacey Taplin Selected answer as best 14th November 2022
Jeroen Geldhof [SLC] [DevOps Enabler]5.50K Posted 14th November 2022 0 Comments
In the connector code it’s possible to add a user level to single parameters.
Using the user level in the security settings it’s possible that way to prevent certain people of seeing the write-part of the parameter or hide the parameter all together.
Since the connector code is potentially also used for other DataMiner users the responsible TAM will make a decision on whether this connector feature request is approved or not.  So best to check with your Skyline contact.
https://docs.dataminer.services/develop/schemadoc/Protocol/Protocol.Params.Param-level.html?q=user%20level
https://docs.dataminer.services/user-guide/Advanced_Functionality/Security/About_DMS_Security/User_rights.html
It’s not locking the parameter since all users with the right user access level can edit the parameter, it can however be used to block certain users or user groups from editing the parameter.
Gerwin van der Kamp [DevOps Advocate]3.71K Posted 14th November 2022 0 Comments
If you don’t want or can’t lock an complete element, then you might try to alarm that parameter, and then either have an user react to it or trigger an correlation rule that will switch it back to the desired state.
Kevin Vermeulen [SLC] [DevOps Member]552 Posted 14th November 2022 0 Comments
Hello Stacey, I tried with the Microsoft Platform driver, Poll task manager and with another user I was not able to set the parameter Auto Clear Task Manager and Poll Task Manager.
Locking can be achieved like so:
Locking and unlocking elements | DataMiner Docs
Kevin Vermeulen [SLC] [DevOps Member] Answered question 14th November 2022
