Can I right click on a parameter and add it to an alarm/trend template?
Solved1.30K views6th July 2023
9
Mark Woodyatt [DevOps Advocate]515 3rd April 2023 0 Comments
Hello All,
Is it possible or can it be possible to right click on a parameter and add it to an alarm template.
For example, some of the parameters are very difficult to find. By right clicking on a parameter and adding it to an alarm template associated with that element would drastically reduce the amount of time to alarm. The parameter values can be set at a second stage.
Rgds,
Mark
Ben Vandenberghe [SLC] [DevOps Advocate]9.62K Posted 3rd April 2023 0 Comments
Just on a side note Mark - have you been introduced to the DataMiner DevOps Professional program?  You can find all relevant information and the link to subscribe here Sign Up as a DataMiner DevOps Professional (skyline.be)
In short, it is a points-based program that can give you certain benefits over time as a community member.  Becoming a member is free, and only takes a minute.
Thank you for being part of our community!
Ben Vandenberghe [SLC] [DevOps Advocate] Answered question 3rd April 2023
