Can I right click on a parameter and add it to an alarm/trend template?
Solved1.29K views6th July 2023
9
Mark Woodyatt [DevOps Advocate]515 3rd April 2023 0 Comments
Hello All,
Is it possible or can it be possible to right click on a parameter and add it to an alarm template.
For example, some of the parameters are very difficult to find. By right clicking on a parameter and adding it to an alarm template associated with that element would drastically reduce the amount of time to alarm. The parameter values can be set at a second stage.
Rgds,
Mark
Ben Vandenberghe [SLC] [DevOps Advocate]9.62K Posted 3rd April 2023 0 Comments
Hi Mark,
If you double click on a parameter, you drill down to the parameter level view.  In that case you will find at the top the following tabs: DETAILS TRENDING HISTOGRAM TEMPLATES.
If you click on TEMPLATES, you can immediately choose to enable / disable monitoring on that metric, and configure the thresholds.  Note when you save that, you will have to choose whether you want to apply that to the current element only, or all the elements that are currently using that template. At the bottom it shows the elements which currently share the alarm template with the element that you are working with.
Isn’t this what you were looking for?
8
Just on a side note Mark – have you been introduced to the DataMiner DevOps Professional program?  You can find all relevant information and the link to subscribe here Sign Up as a DataMiner DevOps Professional (skyline.be)
In short, it is a points-based program that can give you certain benefits over time as a community member.  Becoming a member is free, and only takes a minute.
Thank you for being part of our community!
Ben Vandenberghe [SLC] [DevOps Advocate] Answered question 3rd April 2023
