Can I point two or more independent / separate DataMiner Systems to the same Elastic Cluster?
Solved2.69K views10th July 2023architecture deployment Elastic storage
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K 11th August 2020 0 Comments
Can I point two or more independent / separate DataMiner Systems to the same Elastic Cluster?  Or would they conflict with one another?
Thomas Deweer [SLC]286 Posted 11th August 2020 2 Comments
This is possible, however, conflicts would arise, you would most likely find data of the other cluster which is most likely not desired.
However, there is an internal task for this (DCP135196) so that this could be solved.
Ben Vandenberghe [SLC] [DevOps Advocate] commented 11th August 2020
Thanks for the feedback Thomas. So in conclusion we can say that this is currently not recommended, Skyline has not tested and validated this and it could potentially cause issues. But Skyline is looking into it, it is on the radar of the dev team, and upcoming releases could then potentially support this (timing would depend on complexity and the priority that it would get on the roadmap)
Thomas Deweer [SLC] commented 21st September 2020
This feature is available in DataMiner 10.0.11. RN:27091
