Can (how to) an Automation script run in c#8.0?
Solved1.06K views13th August 2024automation scipt
Mieke Dryepondt [SLC] [DevOps Advocate]3.91K 12th August 2024 0 Comments
  1. Can an Automation script run in c#8.0? When I now check the language version of the Script project via DIS I see it is set to 7.3
  2. How to change it?
I'm running DataMiner version 10.4.9.0-14678
Laurens Vergote [SLC] [DevOps Member] Answered question 13th August 2024
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 12th August 2024 0 Comments
From the documentation, it seems only c# versions up to (and including) version 7.3 are supported.
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 13th August 2024
