Can GetParameterIndexByKey produce null for numeric values?
Solved1.65K views19th July 2023
filiep geeraert [SLC]83 17th December 2020 0 Comments
If you retrieve a table cell via a GetParameterIndexByKey, can this be compared to null?
The table cell is of type : numeric text, double, lengthtype: next param.
The column type is Retrieved.
Laurens Moutton [SLC] [DevOps Enabler]9.93K Posted 21st December 2020 0 Comments
Yes, if the table cell is not initialized then the returned object is null (tested on DataMiner 10.0.12.0)
