Can DataMiner interface with serial devices (eg.: RS-232, RS-422, RS-423, RS-485,…)?
Solved2.44K views7th July 2020data source driver serial
Glenn D'Haene382 17th June 2020 0 Comments
Can DataMiner interface with serial devices (eg.: RS-232, RS-422, RS-423, RS-485,...)?
Glenn D'Haene [SLC] [DevOps Member] Selected answer as best 7th July 2020
Avatar photo
Jan Staelens [SLC] [DevOps Advocate]924 Posted 17th June 2020 0 Comments
DataMiner supports serial communication, allowing protocols to define one or more connections of type "serial". DataMiner runs a process called "SLPort" which takes care of all communication to and from devices connected to either a serial port or an IP port.
So we support both a direct serial cable, if the server itself has those connectors, or through another device that does serial to ip conversion such as a Moxa device.
For more information I would refer you to the DataMiner Development Library that defines how such a protocol can be written using connections of type Serial.
