Build error when using GetDMS in automation script
Solved1.25K views10th July 2023automation scipt
Robin Becker [DevOps Member]1.42K 10th May 2023 0 Comments
Suddenly I’m getting errors when trying to use GetDMS in an automation script. I used the snippet to and added the class library:
error CS0234: The type or namespace name 'Library' does not exist in the namespace 'Skyline.DataMiner' (are you missing an assembly reference?)
Michiel Saelen [SLC] [DevOps Advocate]6.35K Posted 10th May 2023 3 Comments
Hi Robin,
I would suggest using the public NuGet package:
NuGet Gallery | Skyline.DataMiner.Core.DataMinerSystem.Automation 1.1.0.4
For usings:
using Skyline.DataMiner.Core.DataMinerSystem.Common;
using Skyline.DataMiner.Core.DataMinerSystem.Automation;
And then you can use:
engine.GetDms();
Robin Becker [DevOps Member] commented 10th May 2023
Hi Michiel,
That just changes the error to:
error CS0234: The type or namespace name ‘Core’ does not exist in the namespace ‘Skyline.DataMiner’ (are you missing an assembly reference?)
It seems to work when running locally with DIS Inject but not when publishing the script and running it from cube.
Michiel Saelen [SLC] [DevOps Advocate] commented 5th July 2023
Hi Robin,
Sorry for the late reply, did you include the correct NuGet packages?
Can you also share what DIS version or DM version you are using?
Maybe you can push your solution to a public GitHub repo, so we can check?
Robin Becker [DevOps Member] commented 7th July 2023
Hi Michiel,
This issue is being looked at in a support ticket and will hopefully be solved.
