Bridgetech Technologies VB Probe Series 1.4.2.14 – Counting cleared alarms for a channel
58 views2 hours agobridgetech probes Dashboard service
Adrian Marcak160 2 days ago 0 Comments
I would like to display the count of cleared alarms from "Alarms -> OTT Alarms" from a specific channel on the dashboard. I tried something like the following, but without a success:
Is there any way to count these alarms? The driver has a field that displays the number of active alarms overall, but I haven't found anything regarding cleared alarms.
ID:15299 - Description
ID:15302 - Status (Active/cleared)
ID:15349 - Stream Name
As a next step, I would like to sum up the number of alarms from multiple devices.
Thank you in advance for your help.
BR,
Adrian
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 2 hours ago
Miguel Obregon [SLC] [DevOps Catalyst]24.01K Posted 2 hours ago 0 Comments
Hi Adrian,
A possible option is to use aggregation rules to count number of rows based on a condition. For example, I have a table where I would like to count the number of rows where the value of a specific column is set to 'Normal':
Below the aggregation rule:
Small note: To aggregate the values per element I had to create an element property 'Name' and set the value to the name of the element.
And the result:
To display the value of an aggregation rule in a Visio file, you can follow the steps described in Linking a shape to an aggregation rule.
Hope it helps.
