Best way to retrieve elements that are using a certain connector
Solved2.98K views6th July 2023Connector DMS elements
Ana Pinho [SLC] [DevOps Member]1.42K 5th July 2023 0 Comments
Is there any fast and optimized way to retrieve the elements on a DMS that are using a certain type of connector?
I know that we can retrieve all the elements present on the DMS.
Just wondering if we have a call that does the filtering already 🙂
Thank you,
Ana
Ana Pinho [SLC] [DevOps Member] Selected answer as best 6th July 2023
Simon Raine [SLC] [DevOps Member]2.08K Posted 5th July 2023 1 Comment
You can also just go to your surveyor/rootview and click on the hamburger menu and select actions/export. Choose .csv, 'data as displayed on view card'. Then you have a csv with all the info including protocol and version and you can do whatever you want with it.
Simon Raine [SLC] [DevOps Member] Posted new comment 5th July 2023
Simon Raine [SLC] [DevOps Member] commented 5th July 2023
Sorry.. misread your question. You want to prefilter the output. Ignore my answer.
