Best way to join to tables on a LCA
Solved1.38K views25th September 2024LCA low code app
Ana Pinho [SLC] [DevOps Member]1.42K 24th September 2024 0 Comments
Hi dojo,
I have table A, that has two columns (ID (string), Label (string)) and table B with the same two columns.
What is the best way to create table C, on a low code app, that joins the two tables.
Table C should have the rows of A and B and just the two columns (ID, Label).
Thank you,
Ana
Ana Pinho [SLC] [DevOps Member] Selected answer as best 25th September 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 24th September 2024 1 Comment
Hi Ana,
A possible option is using an outer join operation. After the outer join, you can use column manipulation operator (concatenate) to create columns based on the result of the outer join. See example below:
Hope it helps.
Ana Pinho [SLC] [DevOps Member] Posted new comment 25th September 2024
Ana Pinho [SLC] [DevOps Member] commented 25th September 2024
Thank you Miguel! That’s exactly what I needed
