Best way to display Exponential values in Data Page
Solved2.73K views29th June 2020Cube exponential values protocol
Mieke Dryepondt [SLC] [DevOps Advocate]4.13K 29th June 2020 0 Comments
What is the best way to define exponential values in a protocol?
For example a value that can range between 1E-3 and 1E-10
Goals:
  1. readable in a data page
  2. able to trend
  3. able to add alarm thresholds
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 29th June 2020
Laurens Moutton [SLC] [DevOps Enabler]9.86K Posted 29th June 2020 2 Comments
At this moment you're going to have to parse the incoming value and choose a fixed unit (e.g. E-6), this way you'll be able to trend and put alarm thresholds.
It will not be ideally readable as you could have E-3 up to E-10 values that will be a very large or small number being displayed in the E-6 unit.
In the future we're having the dynamic unit which will allow the user to select an appropriate unit, I don't know if we will be able to dynamically change it from inside the driver. That will have to be checked once that feature is available.
Mieke Dryepondt [SLC] [DevOps Advocate] Unselected an answer 29th June 2020
Mieke Dryepondt [SLC] [DevOps Advocate] commented 29th June 2020
Thank you for the answer.
Ideally the Exx is added automatically when a number is very small / large and is displayed next to the unit.
Example: the speed of light displayed value = 2.998 E08 m/s. internal value = 299792458 m/s
Lander Vanhaverbeke [SLC] [DevOps Member] commented 29th June 2020
This is correct. Just some more info about the dynamic units:
Support for dynamic units will be added in 10.0.9 (RN26330) in Visio. However, exponential notation is currently not a part of that feature. So you will be able to display a value in the best fitting unit (for example Hz for small numbers, Ghz for big numbers), but it’s currently not possible yet to automatically convert 1000 E-6 to 1 E-3.
It would certainly be interesting to have that functionality (with and without units). Feel free to create a task to request this feature.
