Best way of exporting trend data
Solved2.83K views14th July 2023data export trend trending
Bethany Sheppard20 7th April 2022 0 Comments
I would like to export trend data for particular parameters from particular elements to csv files saved to my desktop. What's the best way of doing this, and is there a way automate this for regular time intervals?
Rene De Posada [SLC] [DevOps Advocate]1.94K Posted 8th April 2022 0 Comments
Another option could be to enable data offload via file export for the specific parameters. This will allow you already get the offloaded data in in CSV files following the specified data resolution.
Configuring data offloads | DataMiner Docs
Rene De Posada [SLC] [DevOps Advocate] Answered question 8th April 2022
