Best way of exporting trend data
Solved2.81K views14th July 2023data export trend trending
Bethany Sheppard20 7th April 2022 0 Comments
I would like to export trend data for particular parameters from particular elements to csv files saved to my desktop. What's the best way of doing this, and is there a way automate this for regular time intervals?
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 7th April 2022 0 Comments
Hi Bethany,
From cube, you can just right-click any trend graph and choose the export to csv option.
To get trends on a scheduled interval, you could create a dashboard with the relevant trend graphs.
In the scheduler, you can then choose to include the trends as csv.
