Best practices for Cassandra Reaper schedules, gc_grace_seconds and tombstone management
369 views29th October 2026
6
Stefan Schedletzky [DevOps Advocate]2.84K 28th October 2026 0 Comments
Hi everyone,
I'm looking for some advice and best practices regarding Cassandra maintenance in a DataMiner environment.
We are currently running the following setup:
  • DataMiner 10.6 CU5
  • Apache Cassandra 4.1.10
  • 3-node Cassandra cluster on Ubuntu 24.04
  • Cassandra Reaper 3.3.4
  • Scheduled repairs every 7 days
Recently, we encountered an issue where a DataMiner element failed to initialize due to a database error (0x80040226).
After investigating, we found a high number of tombstones in the dmacluster_elementdata.elementdata table. Running a manual compaction on all three Cassandra nodes resolved the issue.
However, we monitored the table over the following days and noticed that the droppable tombstone ratio increased again:
Date
Droppable Tombstone Ratio
October 20 (after compaction)
0.12%
October 22
12.93%
October 23
16.94%
October 26
48.92%
The behavior is nearly identical across all three Cassandra nodes.
The table uses LeveledCompactionStrategy, and Cassandra is performing regular automatic compactions. Nevertheless, the tombstone ratio continues to increase.
During our investigation, we also discovered that Cassandra Reaper had been stopped for approximately eight days. We have restarted it, and the scheduled repairs have now completed successfully.
Questions for the community:
  1. Repair frequency vs. gc_grace_seconds
    The elementdata table has gc_grace_seconds = 86400 (24 hours), while our Reaper schedule runs every 7 days.
    Is this a recommended configuration for DataMiner, or should repairs be performed more frequently? Would increasing gc_grace_seconds be a better approach?
  2. Reaper configuration and table exclusions
    Are there recommended Reaper settings specifically for DataMiner environments?
    I understand that tables using TimeWindowCompactionStrategy (TWCS) should generally be excluded from automatic repairs. Is enabling blacklistTwcsTables: true sufficient, or are there other DataMiner-specific recommendations?
  3. Tombstone accumulation in elementdata
    Has anyone experienced similar tombstone accumulation in the elementdata table?
    Are there recommended adjustments to the compaction strategy or other ways to improve automatic tombstone cleanup without relying on periodic manual compactions?
  4. Reaper reliability
    How do others monitor Cassandra Reaper to ensure that scheduled repairs are actually running and completing successfully?
Our goal is to establish a reliable long-term maintenance configuration and avoid recurring element initialization failures.
I'd be interested to hear how others have configured Cassandra and Reaper in their DataMiner environments.
Thanks in advance for any suggestions or experiences!
Chris Glover [DevOps Advocate] Answered question 29th October 2026
Chris Glover [DevOps Advocate]2.25K Posted 29th October 2026 2 Comments
You have my sympathy, we had a world of pain earlier this year due to excessive tombstones on the elementdata table which prevented elements restarting
  1. We have our gc_grace_seconds set to 172800 (2 days) on the elementdata table. Reaper is set to run every day.
  2. Our reaper looks at all tables, every 3 days, except element data which is reaped daily.
  3. Oh yes, we had an in-house created element that was doing thousands of writes and deletes to a table daily. This meant that the element would not restart as the tombstones were in the millions, thus causing a read timeout. USE VOLATILE TABLES WHERE YOU CAN!
  4. Use the cassandra cluster monitor element (https://catalog.dataminer.services/details/2ed38410-4e76-4081-b630-9c9d14f10db7). You will have to setup so access permissions on the tables. This has a repair History section so you can see when a table was repaired, most recent at the top.
in cassandra.yaml we addjusted the read  range timeoit value to 30s, it defaults to 10. This helps in high tombstone situations
read_request_timeout: 30000ms
range_request_timeout: 10000ms
write_request_timeout: 2000ms
counter_write_request_timeout: 5000ms
cas_contention_timeout: 1000ms
truncate_request_timeout: 60000ms
slow_query_log_timeout: 500ms
native_transport_timeout: 35000ms
There is a reason why we set the gc_grace_seconds to be longer than the reaper run interval, but it was a while ago and I can't remember what it was
You can run this to see howmany droppable tombstones there are per table
nodetool getsstables sldmadb_elementdata elementdata 400157:24 |xargs -I {} sstablemetadata {} | grep -i "droppable"
If you run nodetool repair abainst a table, or a specific elements entry, you need to run it on every node in your cluster. Likewise it's worth installing reaper on every node.
nodetool tablestats sldmadb_elementdata
Will show you the Top 10 elements with the highest tombstone count
If you have cqlsh, or DbVisualizer installed, you can run a very artificaly query such as
SELECT COUNT(*) FROM sldmadb_elementdata.elementdata WHERE d = 4 AND e = 24;
Where d is the DMA ID, and e is the element id. If it takes a long time to return that's the table with high tombstones.
Table compaction can help, or it can make it worse depending on which stratergy your using. As I said above, it's a world of pain!
Good luck!
Chris Glover [DevOps Advocate] Posted new comment 10th November 2026
Stefan Schedletzky [DevOps Advocate] commented 10th November 2026
Hi Chris,
Thanks a lot for your detailed feedback and for sharing your experience! Really helpful.
We've now changed our `elementdata` repair schedule to run daily.
While checking our Cassandra configuration, we also noticed that several other DataMiner tables have `gc_grace_seconds` set to just 4 hours or 24 hours, while Reaper repairs them every 7 days.
Does anyone know if these short grace periods are intentional DataMiner defaults? What would be the recommended approach here: increasing the grace periods, running repairs more frequently, or a combination of both?
Thanks again!
Chris Glover [DevOps Advocate] commented 10th November 2026
Thanks Stefan, glad you found it helpful.
Here's the explanation for why gc_grace_seconds needs to be greater than reaper run interval
Repairs are the only reliable way to deliver a tombstone to every replica, so a full repair of every range has to finish before gc_grace_seconds runs out.
A delete writes a tombstone, and a replica that was down or dropped the write may never receive it.
After gc_grace_seconds, compaction is allowed to purge the tombstone on the replicas that do have it.
If the replica that missed it hasn’t been repaired by then, it still holds the old data. The next repair or read repair copies that data back to the others, so the deleted data comes back.
The rule: repair interval + repair duration + slack for a failed or slow run < gc_grace_seconds.
With a 2-day grace and daily Reaper runs, one repair can fail or overrun and the next one still finishes inside the window. Repairing every 2 days (or less often) would leave no margin.
