Automation to import and activate Zip files from Documents module into a an element table
Solved1.52K views5th December 2023activation automation scipt CSharp documents import file
A B M Sidddique [DevOps Advocate]401 21st November 2023 0 Comments
Hi Dojo community ,
I’m currently working on automating a process within  DataMiner that involves importing ZIP files (not extract) from the Documents module into an element table. Here’s a brief overview of what I’m trying to achieve:
  1. ZIP files stored in a specific folder within the Documents module( this will be done manually).
  2. Transfer the updated ZIP file location onto the element table ( the contents of the zip folder does not need to be read) (automation) .
  3. Activate the associated  ZIP file in the element table (automation)
Fig 1 :Zip folder in the documents module
Fig 2: The element table that needs to be populated with the updated zip file and activate it.
Ideally I want to perform this process by executing a C sharp automation script. Any specific method to import the zip file location and change the file from, code snippets, or examples related to this automation task would be incredibly helpful. Thank you in advance for your assistance!
Kind Regards,
ABM
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 5th December 2023
Gelber Mahecha [SLC] [DevOps Enabler]1.97K Posted 23rd November 2023 1 Comment
Could you please take a look at the answer to this other question?
A B M Sidddique [DevOps Advocate] commented 23rd November 2023
Thank you ! will look into that answer and further clarify
