[Automation] Spectrum Analyzer Reference Line
Solved1.88K views21st November 2024automation scripts preset reference line spectrum analyzer
Yohan Silva [DevOps Enabler]404 15th February 2024 3 Comments
Hello,
I am trying to retrieve the reference line from a preset trough automation, but i have not found any documentation about it, is it possible?
Through automation we have multiples SpectrumPreset methods and they are really helpful to retrieve the parameters saved on a preset, but there is the possibilitie to retrieve the trace saved as a reference line?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 21st November 2024
Michiel Vanthuyne [SLC] [DevOps Advocate] commented 16th February 2024
Hi Yohan, I think this is possible but I have to look it up. Just to be sure: are you referring to a reference line or the reference trace?
Yohan Silva [DevOps Enabler] commented 16th February 2024
Hello Michiel, it is about the reference trace.
Marieke Goethals [SLC] [DevOps Catalyst] commented 21st November 2024
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 4th October 2024 0 Comments
Hi Yohan,
After checking with our experts here, I was informed that you have found another approach for this problem in the meantime. Could you provide some more information on how you approached this, for reference for other users of this forum?
