Automation scripts – revoking element selection privilege on confirmation pop-up window.
Solved1.68K views15th January 2025
Daud Ahmed [SLC] [DevOps Member]404 15th January 2025 0 Comments
While executing automation scripts, a pop-up window appears, allowing the user to select the element on which changes will occur. Is it possible to revoke the element selection privilege for operators(not for administrators) on the confirmation pop-up window?
Kind regards,
Daud
Daud Ahmed [SLC] [DevOps Member] Selected answer as best 15th January 2025
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.39K Posted 15th January 2025 0 Comments
If it fits your use-case the Automation script could be executed from a Visio and with the NoConfirmation option the user will not be presented with this UI. That of course means the dummy values would have been passed on from the Visio.
Miguel Obregon [SLC] [DevOps Catalyst]23.71K Posted 15th January 2025 3 Comments
Hi Daud,
How the user triggers the automation script? If they trigger the script from a Visio overview, a possible option is to use the shape data Level. This shape data allows you to show a button if a user has a specific access level. For example, you can create two buttons:
  • One button (for administrators) that will trigger the script without passing dummy parameters. This will make DataMiner to show the script UI so the user can select the dummy parameter.
  • One button (for users) that will trigger the script passing the required dummy parameters (and adding the option ‘NoConfirmation’). This will make DataMiner to trigger the automation script without user interaction.
Hope it helps.
Miguel Obregon [SLC] [DevOps Catalyst] Posted new comment 15th January 2025
Daud Ahmed [SLC] [DevOps Member] commented 15th January 2025
Thanks Miguel for looking into it, user wants to trigger the script from Visio so "noConfirmation" option indeed fits the requirement.
Nuril Kamarudin [DevOps Advocate] commented 15th January 2025
Thanks, Daud, for pointing this out. Here's what I did:
In the Execute shape’s data value, add these options:
“` |||||NoConfirmation,CloseWhenFinished “` This ensures that no pop-up window appears after the script finishes.
User can also include a UI interaction step in the automation script before execution. This provides an extra check before use any set commands.
Miguel Obregon [SLC] [DevOps Catalyst] commented 15th January 2025
Hi Nuril,
Please keep in mind that operators/administrators will see the same behavior when running the automation script. I understood from Daud's question that the objective was to have a different behavior depending of user permissions.
