Automation Script
Solved1.94K views3rd February 2022Automation script
ryan yahia900 2nd February 2022 0 Comments
I've tried looking through the documentation and can't find anything on this.
Is there a way to return a list of all dma ids on the dataminer system.
Thanks,
Ryan
ryan yahia Selected answer as best 3rd February 2022
Miguel Obregon [SLC] [DevOps Catalyst]23.67K Posted 3rd February 2022 4 Comments
Hi Ryan,
A possible option is using the DataMiner Class Library - IDms methods. For this case you could use the method GetAgents. This method will return a collection of DMAs available in a cluster. You can get the DMA ID through the property Id (IDma properties).
IDms dms = engine.GetDms();
ICollection<IDma> dmas = dms.GetAgents();
foreach (IDma dmaAgent in dmas) {
engine.GenerateInformation("DMA ID=" + dmaAgent.Id);
ryan yahia Posted new comment 3rd February 2022
ryan yahia commented 3rd February 2022
Thank you Miguel, when using the IDms method
I get the error:
“The type or namespace name ‘IDms’ could not be found (are you missing a using directive or an assembly reference?)”
Also while using the GetDms method:
‘Engine’ does not contain a definition for ‘GetDms’ and no accessible extension method ‘GetDms’ accepting a first argument of type ‘Engine’ could be found (are you missing a using directive or an assembly reference?)
Currently using these two references:
What namespace do I have to reference here?
Pedro Almeida [SLC] commented 3rd February 2022
To use the code provided by Miguel, you will need to have the option of Enable Class Library Feature and Automatically generate Class Library code under the DIS Settings.
Miguel Obregon [SLC] [DevOps Catalyst] commented 3rd February 2022
Hy Ryan,
You can find additional information about how to work with the DataMiner Class Library in the DataMiner Automation course:
https://community.dataminer.services/courses/dataminer-automation/
You could review the topics:
– Creating automation scripts using DataMiner Integration Studio (DIS):
https://community.dataminer.services/courses/dataminer-automation/lessons/creating-automation-scripts-using-dataminer-integration-studio-dis/
– DataMiner Integration Studio (DIS) Class Library:
https://community.dataminer.services/courses/dataminer-automation/lessons/dataminer-integration-studio-dis-class-library/
Thank you both,
Will check those resources too!
