Automation script solution: saving compiled scripts as dmapp
Solved2.22K views6th July 2023Automation script solution dmapp
7
Alex Johnson [SLC] [DevOps Advocate]921 20th March 2023 0 Comments
I am trying to save compiled scripts as a dmapp, but the only option it’s giving me is .zip:
The TAM said that it used to be able to be saved as a dmapp, so what could have changed?
When renaming the extension to a .dmapp and trying to upgrade a system with it via client test tool, I get this error:
Is there a reason why this won’t get saved as a dmapp? Is there a way I can add the AppInfo.xml manually to get the upgrade to work?
Thanks in advance,
Michiel Oda [SLC] [DevOps Advocate]3.90K Posted 20th March 2023 0 Comments
Hi Alex
Saving all the scripts as a single dmapp package will only be possible from DIS 2.41. For now you can use the dmapp that is created via the pipeline or make a dmapp package for each single script like Tom mentioned.
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 20th March 2023 0 Comments
Hi Alex, creating a dmapp package is only available when saving a single script, not when saving multiple scripts.
When the xml file of a script is active in Visual Studio, the File > “Save Compiled Script…” option should appear that allows to save as .dmapp.
Tom Waterbley [SLC] [DevOps Enabler] Answered question 20th March 2023
