Automation script slow after fetch DCF and parameters table
Solved1.33K views28th August 2025interactive automation script LCA
Marco Di Blasi526 17th February 2025 2 Comments
Hi all
I’m face a use case where from a LCA, different element begin displayed on a grid, the user when click on one of this tile, trigger an automation script that will take few parameters and a memory file as input.
Starting from there the automation script find the element choosed by the user, pick few information on 2 different parameter table, and later find the right connection element via DCF table.
When all the tasks are done, it will prompt via Interactive Automation script an URL that user will use.
The code is working properly, the only issue in this moment is that something the code is pretty slow, and can take up to 5 min to provide a response, usualy it take instead just 5 sec to execute the script.
So which could the issue of this high slow spike? as it will not be also so slow I don’t think the problem is related to the code, could be the interaction with the LCA?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th August 2025
Tiago Rosa [SLC] [DevOps Advocate] commented 24th February 2025
Hi Marco, the root cause is not immediately clear. Considering the slowness is not always observed, could you post your code here? It might help us troubleshoot this further. Thanks
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th August 2025
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 26th June 2025 0 Comments
Hi Marco,
I noticed that this question has been open for some time now. Do you still need help with this, or have you found the solution in the meantime? If you still need help, could you answer Tiago’s question above? Or if you have found the solution, could you post an answer for reference for other users?
