Automation Script: SetParameterByPrimaryKey too long
Solved1.68K views29th August 2025
MAXIMILIANO FILHO [DevOps Enabler]1.18K 19th February 2025 2 Comments
Hello,
I have an automation script that enables a group of channels on specific AppearTV elements. This automation is straightforward and simply executes the following command:
appearTVElement.SetParameterByPrimaryKey(1643, appearTVData.PK, "Enabled");
The issue is that this command is taking around 8 seconds to execute, and since the groups contain many channels, the overall process is taking too long.
Is there a more efficient way to achieve this?
I have already set the flag:
engine.SetFlag(RunTimeFlags.NoCheckingSets);
Thanks in advance!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 29th August 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 26th June 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 29th August 2025
Edson Alfaro [SLC] [DevOps Advocate]1.76K Posted 20th February 2025 0 Comments
Hi Max,
Maybe you can avoid the SetCheck to make the script faster.
if your execution is from a Visio file, you need to configure NoSetCheck option
Linking a shape to an Automation script | DataMiner Docs
Regards.
Edson Alfaro [SLC] [DevOps Advocate] Answered question 20th February 2025
