Automation Script SetParameter Fail
Solved1.34K views27th June 2025Automation script SetParameter
Yong Ting Lim [SLC] [DevOps Member]261 27th March 2025 0 Comments
I have an automation script that does SetParameters on Buttons.
The process involves first clicking a Confirm Button (Set Parameter) on the Element, followed by a period of .sleep() then clicking the Discovery button (Set Parameter) to repoll data on the Element.
However, I frequently encounter set parameter failures only on the Discovery button. The issue occurs inconsistently, and I haven’t been able to determine the cause.
Does anyone know what might be causing this?
SLAutomation Logs:
2025/03/27 09:20:56.929|SLAutomation.exe 10.4.2343.16222|24560|25596|CActionHandler::SetParameter|DBG|-1|(Script SunAutomationScript/1) Set Parameter 10008/8/4/ failed (: 0x80131500)
2025/03/27 09:20:56.930|SLAutomation.exe 10.4.2343.16222|24560|25596|Script|INF|-1|[Skyline] (Script SunAutomationScript) Log Message: “Unable to do set on Discovery Button ID: DiscoveryButton | (Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Set Parameter (‘_10008_8’:4/) Failed: 0x80004005
at Skyline.DataMiner.Automation.ScriptDummy.SetParameter(Int32 pid, String idx, Object value)
at Skyline.DataMiner.Automation.ScriptDummy.SetParameter(Int32 pid, Object value)
at Skyline.DataMiner.Automation.Element.SetParameter(Int32 pid, Object value)
at SunAutomationScript_1.ToggleInputs.DiscoverServicesAsync(IEngine engine, Element element)”
2025/03/27 09:20:56.931|SLAutomation.exe 10.4.2343.16222|24560|25596|CScriptLoader::ExitNow|DBG|-1|[Skyline] (Script SunAutomationScript) EXIT: “Run|Something went wrong: (Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Set Parameter (‘_10008_8’:4/) Failed: 0x80004005
at SunAutomationScript_1.ToggleInputs.TryRetrieveUpdatedServicesTableRows(IEngine engine, Element element, IDmsTable servicesTable, Object[][]& servicesTableRows)
at SunAutomationScript_1.ToggleInputs.RunToggleInputs(IEngine engine, List`1 irdTypeCheckBoxList)
at SunAutomationScript_1.ToggleServicesProcess.ToggleServicesProcessPresenter.ConfirmButton_Pressed(List`1 IrdTypeCheckBoxList)
at SunAutomationScript_1.Script.<>c__DisplayClass1_0.<RunSafe>b__2(Object sender, EventArgs args)
at Skyline.DataMiner.Utils.InteractiveAutomationScript.Button.RaiseResultEvents()
at Skyline.DataMiner.Utils.InteractiveAutomationScript.Dialog.RaiseResultEvents(UIResults uir)
at Skyline.DataMiner.Utils.InteractiveAutomationScript.InteractiveController.Run(Dialog startDialog)
at SunAutomationScript_1.Script.RunSafe(IEngine engine)
at SunAutomationScript_1.Script.Run(IEngine engine)”
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th June 2025
Jorge Dias [SLC] [DevOps Enabler]5.36K Posted 10th April 2025 0 Comments
Hi Yong,
As discussed, the script code is correct, the problem seems to be either from a communication issue between the DMAs or the element that is busy for a long time when the set is done making it timeout.
