Automation script : GetMatrixInputForOutput method
Solved1.86K views25th February 2021Automation script
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.39K 18th February 2021 0 Comments
Is there an equivalent method to GetMatrixInputForOutput  that gets 'outputs' that are connected to a certain 'input' ?
Wale Oguntoyinbo [SLC] [DevOps Advocate] Selected answer as best 25th February 2021
Wouter Demuynck [SLC] [DevOps Advocate]7.04K Posted 25th February 2021 0 Comments
Hi, there is currently no such call available.
As a workaround, you might be able to call GetMatrixInputForOutput for each output and see which ones return the desired input.
