automation script: context menu
Solved2.72K views10th August 2023Automation ContextMenu
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 20th July 2023 0 Comments
In a connector there's a right-click context menu item for adding entries to a table.
Once clicked it opens an popup to fill in 3 parameters.
Is that possible through an automation script?
Probably it is possible with slnet, but I wonder if this has been done before.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 10th August 2023
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 20th July 2023 0 Comments
Hi Jeroen,
It is hard to know what your use case is. It would be nice to explain that as well in your question.
I assume 2 things:
- In C# block of an automation script, there is a context-menu, which consists of a list with predefined code snippets.
- in a running Interactive Automation script, it is not possible  to have context-menus directly involved in the UI.
HOWEVER, if you use the UI block type 'Parameter', it will resolve the given parameter data into a parameter control, like the one you see in Data Display.
So this is the same one that you would describe/configure via the protocol.
In your use case, it could be possible if you will pass the table parameter in your script as UI block. Please check the documentation for more information.
Hope this will help you further.
Matthias Declerck [SLC] [DevOps Advocate] Answered question 20th July 2023
