Automation Script as Code Library dll reference issue
Solved3.05K views12th April 2022Automation script C++ code library DLL
Philip Argent [DevOps Advocate]1.13K 11th April 2022 0 Comments
I'm looking at using compiling a C# code block as a library to simplify some of our scripts, as we have several methods that are duplicated over a lot of them, everything works as explained in Compiling a CSharp code block as a library until I get to the script reference part, once uploaded the reference shows as "C:\Skyline DataMiner\ProtocolScripts\" instead of "C:\Skyline DataMiner\Scripts\Libraries\".
Manually editing the path to the correct one resolves the issue, but I don't want to have to do that every time I upload a change; I can use a ref parameter directly to it, but then that's linked directly to a specific version, which might cause issues down the line.
Also testing edits on the library I see a new version is created each time with a new date in "C:\Skyline DataMiner\Scripts\Libraries\", but then I need to update the reference in my project to use the new version, which does make sense for version compatibility, but I then end up with different version of the dll between our dev and production systems unless I copy one of the files from one to the other and replicate it.
Wannes Wittevrongel [SLC] [DevOps Member] Answered question 12th April 2022
Gelber Mahecha [SLC] [DevOps Enabler]2.03K Posted 11th April 2022 1 Comment
Hi Philip,
Are you referring to the shared library project in the VS solution? (Instead of browsing the DLL file where you have that shared code):
Adding the reference will prevent errors during the compilation at VS, but you also need to set the <Param type="scriptRef"> tag in the XML of the automation using that shared library so that when the automation is loaded, DataMiner will automatically resolve a valid reference to the shared code without having to specify any path to a file.
Gelber Mahecha [SLC] [DevOps Enabler] Answered question 11th April 2022
Philip Argent commented 12th April 2022
Hi Gelber,
See my comment/answer below.
