Automation – Is every script run in the same AppDomain?
Solved1.87K views7th September 2022Automation automation scripts
Gellynck Jens [SLC]2.72K 7th September 2022 2 Comments
Is an Automation Script executed in a unique AppDomain or are AppDomains shared for all scripts?
Gellynck Jens [SLC] Posted new comment 7th September 2022
Wim Bruynooghe [SLC] [DevOps Advocate] commented 7th September 2022
Microsoft actually recommends to not use AppDomains anymore, as they are resource-expensive. For code isolation, use separate processes or containers as an alternative. See https://docs.microsoft.com/en-us/dotnet/core/porting/net-framework-tech-unavailable#application-domains
Gellynck Jens [SLC] commented 7th September 2022
Interesting, thanks for the info!
Wouter Demuynck [SLC] [DevOps Advocate]7.06K Posted 7th September 2022 0 Comments
All automation scripts currently get executed within the same AppDomain
Gellynck Jens [SLC] Selected answer as best 7th September 2022
