Automation: Handle “Could not verify that parameter was correctly set (50 retries).”
Solved1.91K views25th May 2022Automation
Robin Becker [DevOps Member]1.42K 23rd May 2022 0 Comments
What’s the best way to handle the catch and handle the error “Could not verify that parameter XXXX was correctly set (50 retries).” in an automation script?
Robin Becker [DevOps Member] Selected answer as best 25th May 2022
Joey Vanhalst [SLC] [DevOps Advocate]2.17K Posted 23rd May 2022 4 Comments
Hi Robin,
By default, when doing a set on a parameter, DataMiner will check if the value changed in the corresponding read parameter. The error you encounter is because this check failed (will internally verify 50 times).
This setting can also be disabled, by disabling the following option (when executing the script from Cube):
Robin Becker [DevOps Member] Posted new comment 25th May 2022
Robin Becker [DevOps Member] commented 23rd May 2022
Hi Joey,
Sorry for being unclear. I’m actually looking for how to catch the error in the script and execute C# code if the script throws the errors. As of now a script would continue after the SetParameter call without knowing if it failed or not, which might lead to unwanted consequences. Because the method seems to be executing asynchronously, a normal try-catch is not possible.
Jochen Dewachter [SLC] [DevOps Member] commented 23rd May 2022
Hi Robin, it’s not async. It doesn’t throw an exception because the SET as such succeeded and there’s no check done after the SET (if you uncheck that checkbox Joey mentioned). So there’s no exception to catch in that case.
If you uncheck the checkbox that Joey mentioned, it’s only going to raise an exception if the SET itself (not the check after SET) fails. E.g. if your parameter doesn’t exist.
Jeroen Geldhof [SLC] [DevOps Enabler] commented 23rd May 2022
It will indeed be necessary to add a checking mechanism.
Typically this is done in a for loop in which a engine.sleep is added and a parameter read action. The for loop makes sure there’s a maximum amount of read actions and is exited early when the set succeeded.
ScriptDummy dummy = engine.GetDummy(“dummy1”);
bool setSucceeded = false;
dummy.SetParameter(8,15);
for (int i = 0;i<10;i++)
engine.Sleep(1000);
int iValue = Convert.ToInt32(dummy.GetParameter(8));
if (iValue == 15)
setSucceeded = true;
break;
if (setSucceeded)
engine.GenerateInformation("the set succeeded");
else
engine.GenerateInformation("the didn't succeed");
Robin Becker [DevOps Member] commented 25th May 2022
@Jeroen: I see. Would this require the write param to be setter=”false” and update the read param programmatically?
