Automation – Get Parameter Value and send to email by using automation script actions
Solved719 views12th September 2025Automation automation scripts
Jeeva Suria Rajah [SLC] [DevOps Enabler]1.86K 3rd June 2025 0 Comments
Hi All,
I have a request from the customer where they would like to retrieve parameter values from one or more elements and send them via email using automation.
Is it possible to achieve this using only automation script actions, or would we need to create C# code for this?
Open to any ideas. Thanks!
Pieter Carlu [SLC] [DevOps Advocate]260 Posted 3rd June 2025 0 Comments
It is highly recommended to use C# code for this.
You can use the SendEmail method on the engine object for this. More information can be found here: https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Automation.IEngine.SendEmail.html?q=sendemail
