Automation: error CS8179: Predefined type ‘System.ValueTuple`2’ is not defined or imported
Solved2.27K views21st January 2022Automation
Jeroen Geldhof [SLC] [DevOps Enabler]5.49K 20th January 2022 1 Comment
Suddenly an automation script has parsing errors, and I’m not quite sure why it’s suddenly giving this error or how to resolve it.
Message : Automation script ‘Sencore Video PID set’ failed to execute (ScriptErrorType: ErrorType) : (after retries) (Code: 0x80040251) Skyline.DataMiner.Net.Exceptions.DataMinerException: No Assembly found for cookie 5
(40,23): error CS8179: Predefined type ‘System.ValueTuple`2’ is not defined or imported
(40,72): error CS8179: Predefined type ‘System.ValueTuple`2’ is not defined or imported
(40,54): error CS8179: Predefined type ‘System.ValueTuple`2’ is not defined or imported
(46,17): error CS8179: Predefined type ‘System.ValueTuple`2’ is not defined or imported
(47,21): error CS8179: Predefined type ‘System.ValueTuple`2’ is not defined or imported
(67,62): error CS8179: Predefined type ‘System.ValueTuple`2’ is not defined or imported
(67,51): error CS8179: Predefined type ‘System.ValueTuple`2’ is not defined or imported
(99,8): error CS8137: Cannot define a class or member that utilizes tuples because the compiler required type ‘System.Runtime.CompilerServices.TupleElementNamesAttribute’ cannot be found. Are you missing a reference?
(99,8): error CS8179: Predefined type ‘System.ValueTuple`2’ is not defined or imported
(99,38): error CS8179: Predefined type ‘System.ValueTuple`2’ is not defined or imported
(27,9): warning CS0219: The variable ‘valuesServiceId’ is assigned but its value is never used
(29,7): warning CS0219: The variable ‘tempId’ is assigned but its value is never used
(226,18): warning CS1701: Assuming assembly reference ‘mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ used by ‘Interop.SLDms’ matches identity ‘mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ of ‘mscorlib’, you may need to supply runtime policy
(230,4): warning CS1701: Assuming assembly reference ‘mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ used by ‘Interop.SLDms’ matches identity ‘mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ of ‘mscorlib’, you may need to supply runtime policy
The script has following imports
using Interop.SLDMS;
using System;
using System.Collections.Generic;
using System.Globalization;
using System.Linq;
using System.Text;
It also has following dll references
System.Linq.dll
System.Core.dll
C:\Skyline DataMiner\Files\Interop.SLDMS.dll
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 21st January 2022
Miguel Obregon [SLC] [DevOps Catalyst] commented 20th January 2022
Could it be the case that the .NET framework has been updated/patched?
I quickly checked a similar error in StackOverflow:
https://stackoverflow.com/questions/38382971/predefined-type-system-valuetuple´2´-is-not-defined-or-imported
Matthias Declerck [SLC] [DevOps Advocate]2.99K Posted 21st January 2022 1 Comment
This error log reminds me of a known issue, namely one of the files of the upgrade packages was not correctly updated. Most of the time, SLHelper is affected with this problem. I’m not sure if the same solution would help to resolve the problem in Automation.
Investigation: please do check the System.ValueTuple file in C:\Skyline DataMiner\Files\
Proposal: it must be replaced to version 4.6.26515.6 if it has a older version.
– you can change this file manually.
For Skyline users: I put a copy in S:\Public\DataMiner Software\Downloads\
– Upgrade DataMiner to a more recent version.
This issue is resolved in summer of 2021.
Hope this helps you further
Jeroen Geldhof [SLC] [DevOps Enabler] commented 21st January 2022
It’s indeed an older version. I’ll give it a try
