automation check for timeout
Solved2.49K views14th June 2023Automation script timeout
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 4th January 2023 0 Comments
What is the correct method to check for a timeout state on an Element object in automation?
We're running a backup script for IDP configuration.
Since it's not using dummies, it's not failing the script, but we should still check for a timeout on the element before attempting to capture the config file from the managed element.
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 4th January 2023
Jens Vandewalle [SLC] [DevOps Advocate]10.00K Posted 4th January 2023 0 Comments
Hi Jeroen,
When you use the Code Library you can make use of below code example
Jens Vandewalle [SLC] [DevOps Advocate] Answered question 4th January 2023
