Ateme Titan Edge – SRT Output Status and Bitrate not available per Connection
Solved649 views12th August 2026Ateme Titan Edge bitrate Output Status SRT
Daniel Lentoiu [DevOps Member]94 3rd August 2026 0 Comments
Hi all,
I have a Ateme Titan Edge device onboarded and I would've expected that inside Dataminer for a SRT output to see which of the connections (IP1, IP2, IP3, IP4) is active, what is the Status (as in "connected"-highlighted in Green) and what is the Bitrate of the connection (highlighted in Green - the Connection 1 has 13.004 Mb/s - TS included).
What I see is the overall Output 1/1 bitrate - as in 12 Mb/s  but not the "subset" of Connection/s per Output; multiple customers/Public IPs could potentially benefit the same Output- as in Connections. (IP1 and IP2 could be Enabled at the same time)
I have enabled also the DVE and the info is missing as well.
(Image on top is from Dataminer Cube
Image bellow is from web GUI of a Ateme Titan Edge device)
I am not sure where to look for this info or if it is missing ?!
Thanks.
Daniel Lentoiu [DevOps Member] Selected answer as best 12th August 2026
Fenta Alemahu [SLC] [DevOps Advocate]1.43K Posted 12th August 2026 0 Comments
Hi Daniel,
Those SRT Output Status parameters are not implemented in the current version of the Ateme Titan Edge connector. But these metrics can be integrated in DataMiner. You can reach out to your Skyline contact so that these parameters can be implemented in future versions of the connector.
Kind regards,
