Async HTTP Request from Automation script?
Solved1.97K views19th January 2023Automation
6
Robin Becker [DevOps Member]1.42K 18th January 2023 0 Comments
Would it be possible to do send an async HTTP request from an automation script? For example using the HttpClient-class? I want to call an external API based on a correlation rule.
I’ve tried experimenting a bit, including using sub-scripts but I can’t really get any output.
Is there some other best-practice?
Robin Becker [DevOps Member] Selected answer as best 18th January 2023
Jens Vandewalle [SLC] [DevOps Advocate]10.00K Posted 18th January 2023 3 Comments
Hi Robin,
I’ve used below code in the past to send a async HTTP request
public class Script
private static HttpClient httpClient = new HttpClient();
var result = GetResult();
private static myClass GetResult()
var response = httpClient.PostAsync(new Uri(“url”), content).Result;
var responseBodyJson = response.Content.ReadAsStringAsync().Result;
var jsonObject = JsonConvert.DeserializeObject<myClass>(responseBodyJson);
return jsonObject;
Robin Becker [DevOps Member] Posted new comment 19th January 2023
Robin Becker [DevOps Member] commented 18th January 2023
It was the .Wait-function that solved it, thanks Jens!
Jens Vandewalle [SLC] [DevOps Advocate] commented 19th January 2023
Hi Robin, I’ve made some changes to my code
– HttpClient is now a shared field. See more details for this change in https://www.aspnetmonsters.com/2016/08/2016-08-27-httpclientwrong/
– I don’t use the .Wait function anymore since the .Result function already makes it synchronously. In general automation scripts are executed sequentially, so therefore we should try to avoid async code as much as possible.
Robin Becker [DevOps Member] commented 19th January 2023
That makes sense.
