Assigning more Configuration Elements to Automation Script
1.02K views4th June 2026Automation script solution
Gijs Kregting46 3rd June 2026 0 Comments
Hello Skyline Community,
I'm using a automation script where each night a lower priority alarm template is assigned to a configuration element, and in the morning the script activates the regular alarm template again.
However I want to assign this script to a large amount (300+) of elements, and the only way to do this is by manually creating dummies. Is there a way to assign a large amount of Configuration elements under a single dummy? Or maybe choose all elements under a dummy which use a specific alarm template?
Thank you
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 4th June 2026
Tom Waterbley [SLC] [DevOps Enabler]10.36K Posted 3rd June 2026 1 Comment
Hi Gijs,
You don't necessarily need an input dummy parameter to access elements from an Automation script. Instead, you can retrieve the required elements directly in code. For example:
var filter = new ElementFilter
ProtocolName = "Protocol Name",
ProtocolVersion = "Production",
var elements = engine.FindElements(filter);
foreach (var element in elements.Where(e => e.RawInfo.AlarmTemplate == "..."))
element.SetAlarmTemplate("...");
Depending on your use case, there are other ways to retrieve elements as well. For example, if all relevant elements are grouped in a view, you can retrieve them as follows:
var elements = engine.FindElementsInView("View Name");
This approach avoids the need for a dummy parameter and gives you flexibility in selecting the elements you want to work with.
Gijs Kregting Posted new comment 3rd June 2026
Gijs Kregting commented 3rd June 2026
Hello Tom,
Thank you for your reply. I'm not the best in creating C# code and was hoping for a "GUI solution", but I'm going to give it a try.
