Are Information events subject to same settings as Alarm events?
Solved2.06K views11th July 2023alarms database
Jeff Douglass870 23rd November 2020 0 Comments
Are information events also subject to the System Center->Database->Maintenance->Limit alarms by maximum number setting? In other words, if "Limit alarms by maximum number " is set to 300000 then is the info database table that stores all the information events also limited to the same 300000 number of events?
Thanks
Marlies Vandenberghe [SLC] [DevOps Member]2.98K Posted 24th November 2020 1 Comment
That is a correct statement, on a MySQL system you can limit by number of events and this setting indeed immediately applies to both alarm and information events. From then onwards the delete query will take this new number into account on that DMA (which runs +- every hour).
On a Cassandra system you can only configure a limit by time since everything is based on a time to live in Cassandra but here we have the same thing, if you limit by time it will immediately apply to both information and alarm events.
Interesting note: this is only for new events because we have to set the time to live before we store the data.
Jeff Douglass commented 24th November 2020
Thanks for the response. I am currently working with our IOC team interface to see if there is a way to decouple the Alarms and Info settings and it looks like this may be possible by editing the DB.xml file. and removing the Info table from the section. Just as a suggestion, it would be nice to have this info in the help somewhere. It might be there somewhere but I was unable to any find it.
Thanks again.
