Apache Cassandra Cluster Monitor – Method not found exception
Solved2.63K views11th January 2022Cassandra exception QAction scripting
Jens Vandewalle [SLC] [DevOps Advocate]10.09K 11th January 2022 0 Comments
I'm testing the new Apache Cassandra Cluster Monitor connector and noticed below exception in the element log file:
2022/01/11 12:49:31.841|SLManagedScripting.exe|ManagedInterop|ERR|0|5|QA3|2|Run|Exception thrown:
System.MissingMethodException: Method not found: 'System.Guid Cassandra.Host.get_HostId()'.
   at QAction.ParseCassandraNodes(CassandraDb cassandra)
   at QAction.Run(SLProtocolExt protocol)
The protocol solution has no builds issues and all necessary DLLs are added in the ProtocolScripts folder.
Does someone has an idea why this fails?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 11th January 2022
Jens Vandewalle [SLC] [DevOps Advocate]10.09K Posted 11th January 2022 0 Comments
The problem was that we placed the necessary Cassandra DLL in the ProtocolScripts folder, while DataMiner has a Cassandra DLL of its own in the files folder. When doing a dllImport on a QAction, DataMiner will first look for a reference in the Files folder before looking in the ProtocolScripts folder.
Unfortunately, the Cassandra DLL in the files folder doesn't contain all properties that are needed for the connector to work. Therefore the developer will change the name of the Cassandra DLL so that it can be placed in the ProtocolScripts folder and the connector will use the correct DLL.
