Alerts are not generating for some Specific Sites
340 views20th March 2026
Roshan Chaudhary127 1st October 2025 3 Comments
Hello Team,
There are Multiple Sites setup on Dataminer however Alarms are generating but client is not receiving emails for some specific sites.
Where can I check on it, Kindly help
Marieke Goethals [SLC] [DevOps Catalyst] Answered question 20th March 2026
Miguel Obregon [SLC] [DevOps Catalyst] commented 2nd October 2025
Hi Roshan,
Please could you provide a bit more detail about your current integration?
– Are you running multiple agents across different sites, and experiencing issues with email notifications on some of them?
– Do you have a single DMA where multiple sites are represented through DataMiner views, and some of these views are not triggering email notifications?
Roshan Chaudhary commented 3rd October 2025
Hi Miguel, Thank you so much for your response..
Yes it is a single DMA where Multiple sites are represented through Dataminer views..
When I checked in Alarm Console Alarms are generating but client is not able to receive them on email that too for some particular sites other sites they are receiving the alarms
Miguel Obregon [SLC] [DevOps Catalyst] commented 16th October 2025
Hi Roshan,
Thanks for the additional information. Please could you let me know how the email notifications are triggered?
Via correlation rule, correlation + automation script, Alerts?
Marieke Goethals [SLC] [DevOps Catalyst]7.33K Posted 20th March 2026 0 Comments
I noticed that this question has been open for some time now. Do you still need help with this, or have you found the solution in the meantime? If you still need help, could you answer Miguel’s question above? Or if you have found the solution, could you select this answer (using the ✓ icon) to indicate that no further follow-up is needed, or post an answer of your own for reference for other users?
