Alarms Description – Simple Way to put a Description/Translation on a Alarm
Solved2.91K views18th July 2023alarm description
Thomas Vogel376 21st September 2021 0 Comments
Hello Dojo-Community,
i look for a simple way to put a description/translation on a alarm; so an operator can grasp the problem on sight by looking at the description. For the time I used a correlation rule as a workaround, but it is not really practical.
-> Example: State is "on" or "off" & i want to show that "on" is an active backup.
So is it possible to change the value without using a correlation rule?
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 21st September 2021 0 Comments
Hi Thomas,
Would the comment field be an option for you? You can visualize this by enabling the "comment" column and make it easy to add one by adding the "Add comment" column from the "action" columns.
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 21st September 2021
