Alarm View – Reports – Setting as a default
Solved1.01K views27th June 2025Alarm View Reports
Mark Woodyatt [DevOps Advocate]515 1st April 2025 0 Comments
Hello All,
Is it possible to create a linked tab that always shows a Reports View please?
BR. Mark
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th June 2025
Steve Purcell [SLC] [DevOps Advocate]2.63K Posted 10th April 2025 1 Comment
Hi Mark,  I did not see a way to do this through the Alarm Console.  We do have a standard Dashboard available from the catalog Alarm Report | Catalog if that would work for you.  You could then link the dashboard to a Visio if needed in Cube or create a Dashboard for alarm monitoring rather than Alarm Console depending on what you are trying to accomplish.
Mark Woodyatt [DevOps Advocate] commented 17th April 2025
Hi Steve, Thank you for the replies. I will try this but I don't think it will work with our workflow as it's clicking away & I'm trying to reduce the amount of clicks that the teams make. KR, Mark
